I have a 96 454 EFI Mercruiser inboard/outboard BRAVO. Its a strong running engine with one exception. Once I run it at RPM (3K for over 5 minutes) if I shut down it never wants to start again. Its very similar to vapor lock, but since its fuel injected I've kind scratched that one off. The crazy thing is once its cooled down (4 or 5 hours) its starts right back up on the first crank. <br /> The way I've been solving this problem of not restarting is I've been putting the throttle in neutral and manually giving it gas and turning the starter over & over & over. Doing this it finally catches and cranks up. But, now my starter burned out and I've replaced it but the problems with the fuel/starting still exist?? I have no idea what the problem is? I want to start with the fuel pump but before I started I wanted to get some different looks??<br /><br />Thanks,<br /><br />jarrett
