455 olds- antifreeze
moondog398
Need to winterize- 455 olds- hardin-berkely drive- how much 50/50 antifreeze and where proper place on hardin- berkely set up to place it ?
Re: 455 olds- antifreeze
I suggest marine antifreeze at full strength for winterizing. PG antifreeze is GRAS (Generally Regarded As Safe) where EG antifreeze is poisonous.
Ayuh,... Welcome Aboard,....
Drain all the water out of it, 'n ya don't need Any antifreeze....
Air don't freeze....
moondog398
Im a novice, but i presume its the hose comming off the berkely that goes to the block? Air do get cold- but no freeze and expantion- am i in the right place? Thanks
Ayuh,.... Post some pictures...
There's only 'bout a million ways to plumb a Jet....
moondog398
The hose from berkely runs underneath , splits up to front bottom of hardin exhaust baffles- this surely wont drain the block. Can i pour antifreeze in thru the thermostat housing ? Berkely is h 2484 1976
sdowney717
If you have a wet vac, then you can likely suck out the water.
One of my block drains snapped off, so I had to pull the intake and could not drain it, but a wet vac was able to suck out enough to drop the level low enough to pull the intake.
I keep antifreeze in the engine year round, which is FWC.
instead of a brass plug, the engine had a cast iron 1/4 pipe thread plug and the top is completely sheared off on one side of the block.
Ayuh,.... The Block has Drains,.. Find 'em, 'n Remove 'em...
'n make sure they actually drain...
