I have a 1970 455HA 45HP Chrysler Magneto that I purchased as a project. The motor has not been run in some time.
THINGS I'VE REPLACED/DONE SYSTEMATICALLY AS I TRIED TO START THE MOTOR:
1) Charged the battery. (Did this before I tried to start)
2) New gas tank and gas tubing. (Did this before I tried to start)
3) I went through all the wiring and cleaned it up. (Did this before I tried to start)
4) I changed the points/condensers and gapped them per spec (per Seloc Manual).
5) The plug wires aren't great but since they are part of the coil, I left them on for now.
6) New spark plugs, gapped per spec.
7) I bought a carb kit, cleaned and replaced parts in the carb. Adjusted float per spec.
TRIED TO START
1) Both plugs are getting a spark
2) Fuel is getting to the carb. Unhooked gas line at carb and gas comes out both with primer ball and with fuel pump.
3) Sprayed starting fluid into carb but no indication of start, slight backfire.
4) Switched plug wires to make sure, but same results.
5) Removed plugs after each attempt to start but there does not seem to be any gas.
6) There seems to be some exhaust smoke as if there is some gas firing.
7) Tried starting with slight acceleration.
It seems to be a fuel issue but I'm not sure why when I spray starting fluid I get no results.
TRIED TO START
