45hp chrysler need help!!!!
davpen
i bought this motor two yrs ago. this spring the starter sticks and won't spin the motor over after it did before i took the plugs out and replaced them. the starter engages then humms. just had it rewired last fall. i'm not much of a mechanic when it comes to outboards. anyone no someone in green bay wi.:confused:
fucawi
Banned
Re: 45hp chrysler need help!!!!
sounds like a bad connection ...next time you try it quickly touch the battery connections and earth and solenoid .if any are hot thats the problem...thick starter cables and a good battery are essential with these motors I have the 35hp....
BuzzStPoint
Yep, double check your connections. Make sure they are clean and tight. Same for the battery connections and have a fully charged battery.. Switch the battery for a test as well.
Jump the Solenoid to bypass and see if the starter cranks. This will tell you if the solenoid is bad.
Not in Green bay... West of you.. Stevens Point.
