470 Breezeworks Conversion
WC190
Hi all, I'm new here but just wanted to ask if this breezeworks conversion kit is an easy upgrade? 89' 3.7 w/ps on wellcraft 190 classic, thanks!
Bt Doctur
There is a better kit on the market.it uses your engine pully not one adapted to your pully
salty3rd
The Breezeworks kit does use your engine's pulley. I Installed and used this kit with power steering around 6-7 years ago and didn’t have any issues for the few years I had the boat after that. If I recall their is a little wiring involved and use need to relocate the coolant reservoir. Not to bad.
https://forums.iboats.com/forum/eng...23-mercruiser-470-alternator-replacement-kits
Bt Doctur
Unless they changed, they supplied an additional pully that needed to be centered on the harmonic balancer, the pic in that post is the other type not from Breezeworks
salty3rd
Sorry I disagree, look at the bracket in both pictures and compare it to the Breezeworks website. The pictures in the older posts are the Breezeworks setups; and they both use the original pulley on the harmonic balancer.
https://breezeworks.net/product/low-mount-kit-with-power-steering/
nola mike
No, mine used the original pulley as well. Breezeworks. No p/s, don't know if that makes a difference
