hardwater fisherman
- Mar 19, 2010
- 1,725
I have a prop that is part number 48-43586-13... I believe the 13 is the pitch.. But there is no diameter stamped on it..It measures around 9 1/4".. It came with a 1994 20hp I have..I was getting around 5200 RPM WOT with this prop... I have since put a 25hp carb on the motor and the RPM went up to 5650-5700 RPM.. I bought a 10 3/8 x 11 prop and it gives me only 5450 RPM... I thought the drop in pitch would give more RPM and not less... So will the smaller diameter offset the pitch? My local shop was not able to find the part number and I can not find out much about the prop... I have seen the number 48-43586A40-13 but it is 10 3/8 diameter...
