Motor sat 5 years with no gas in carb. I cleaned the carbs. It runs great, except it wont idle in neutral. I have to throttle up the enging then quickly put it in gear or it will die. I used carb cleaner in spray can. Is that enough pressure to clear debris or do I need to pull them again and use compressed air? Could it just need the idle speed increased? If so how could the idle have gotten out of adjustment? All adjustments were put back exactly as found.
