In the process of replacing my seawater pump in my 04 stingray. For the life of me,why can't they engineer things a little different? To get to the 6 10mm bolts is (at least in my boat) cruel and unusual punishment! The two studs that hold the idler wheels for the serpentine belt are at least 11/2 inces too long which prevents sliding the assembly forward because of the fuel tank proximity. I will be installing a new pump...my thoughts are to drill out the six threaded holes so I can feed bolts from behind and tighten nuts from the front...will be a much easier install....does anyone see a problem doing this?
