4hp-Mercury no water from the outlet
sarantis
According to my experience in Mercruiser i would say that if the water inlet was covered by water the water pump would work.But either i have some leak or my assumption is not right ,or it sucks air from the vent hole.Water comes out normally only when the water covers the red line.Please help.(Test carried out with a drill attached to the top of the saft).
sarantis
Re: 4hp-Mercury no water from the outlet
Sorry ,instead of vent hole i wanted to say drain hole in the front at the base of impeller housing.Anybody knowing the minimum lineof sea level?
