Re: 4hp seahorse only only runs when bulb is constantly pumped
OK, have you checked to be sure the tank is vented?? If the vent is open, check the fuel pump. Disconnect fuel line from carb and put this fuel line in a tin can. Pull rope a few times, if you don't see fuel being pumped into can, rebuild or replace fuel pump.
