4x4 conversion
jonboat2
Does a anybody know if the trans/transfercase from a bronco fit my f150
Mine: '87 f150 2wd 5.0
Parts truck '88 bronco
Also would $300 for the front ttb setup be a good price, everything is included. (all suspension parts)
Thanks for any help.
NYBo
Re: 4x4 conversion
If the motors are the same, the transmission and transfer case should mate up. However, the suspension parts are another matter. I think Ford used entirely different front suspension layouts for 2WD and 4WD trucks.
Re: 4x4 conversion
2WD and 4x4's have different frames
MTboatguy
Re: 4x4 conversion
I have owned both the vehicles you are talking about, more than once.. I can tell you from experience, it is cheaper to buy what you want, not an easy conversion at all..
It can be done, (don't ask me how I know! :eek: :() But as I said, it would be cheaper to buy an 87 4x4 pickup than try to do the conversion..
rbh
Re: 4x4 conversion
YUP!!!, buy what you want, do not go DR Frankinstien/Frankenwrech trying to make one!
NSBCraig
Re: 4x4 conversion
I'd put a straight axle under the front, it's an easy conversion, there's a couple shops around here do it all the time. The ford ifs is junk.
scrit9mm
Re: 4x4 conversion
+1
headache for sure! unless you are one of the host's of Spike TV's Offroad
stackz
Master Chief Petty Officer
Re: 4x4 conversion
fordf150.net
and
fullsizebronco.com
probably your best tech bets on this.
