I have a 1998 5.0 Alpha in a 1998 Chaparral 2130. The engine has 200 hours. I just installed #1 battery and have a #2 battery which was installed from previous owner. Cleaned all the cables which took of the power off the boat. The battery switch works fine. Off,1,All,and 2 . Will start easily and runs great for approx. 40 seconds and quits. Temp, oil , voltage all remain normal. I have checked removed and drained the fuel water separator and reinstalled. Thought it was maybe the alternator over charging. So I isolated the alternator and ran on only battery. No change still quits after 40 seconds. The only thing I have done different was install the new battery.<br />Is there any type of reset switch that needs to be reset after removing power from the boat? Or do you have any ideas.<br /><br />Thanks for your time,<br /><br />Bruce Goldring<br />FLA
