When I go to start my 5.0GI I leave the throttle at the idle position. Turn the key on for a couple of seconds and then turn the motor over. I usually starts right away and revs to about 1800rpm and then dies. I turn the key to the start position again and it immediately starts and runs normally at about 650rpm. It didn't used to do the first routine. Any suggestions what I can to make it start and run normally on the first attempt. This is only happening when the engine is cold. Or am I being too fussy? Motor runs beautifully otherwise and is super fuel efficient.
I just changed both fuel filters, plug wires, plugs, rotor and cap. The only thing that hasn't been changed is the coil but I can't really see that being the problem.
Any suggestions or should I just leave it alone?
