5.0 glh. Convert from sea water cooling to closed system
bsistrunk77
I live in South Louisiana. We have access to salt and freshly water. I got a deal on a glastron gt 205. I'd like to be able to run in salt water. I was advised to avoid this unless I convert to a closed system. My question is is it worth it or should I unload it and get a boat set up for it. Looking at parts online it seems it'll cost at least $2000 or so. Any advise would be great.
spoilsofwar
What year is the boat? It may have a hose flush fitting already installed.
bsistrunk77
2007 glastron gt 205 with 5.0 gl-h volvo penta. It has a flush kit and we use it every time we come in from an outing. I was told. If I continue to run it in salt water I would be replacing the engine in 2-3 years. I've only ran outboards in the past so I am not experienced with in boards. Also we replaced the 5.0 with a 350 Chevy marine longblock motor from gearheads last spring. Fyi
spoilsofwar
Replacing the manifolds and risers, maybe... Replacing the engine? No.
It's saltwater, not radioactive waste.
njlarry
I was told by a supplier of fresh water conversion kits that it would do more harm to convert an older engine. Goes against common sense and I still have my doubts about it but they could have just sold it to me.
A fresh water flush is a must. Every two years I would remove and inspect the exhaust risers, replace the gasket and retorque.
Converting older motors is difficult because sediment in the block cloggs the heat exchanger.
Use the flush kit, go boating. If you boated every day in salt water and didn't flush, assume 3-5 years for the exhaust manifolds. If you flush, that would be 8-10 years
Fishermark
I ONLY boat in salt water and amazingly enough - the engine lasts! Salt water is very corrosive, and yes, you have to stay on top of things and keep them painted and lubricated... but the engine block will last years, if not decades with proper care.
