Augoose
- Mar 21, 2010
- 1,223
Does anyone (Don?) have a link to a manual which would contain the fluid specs, specifically the reservoir capacity for the power steering pump, on a 5.0 GLPWTR? I followed the links in the sticky area and although they point to some pretty good general maintenance stuff, none speak about the reservoir capacity.
Bottom line is that I've got to replace a high pressure hose and bleed the system and need an idea as to how much ATF I need to buy at the store.
Thanks!
Also, are there any specific steps to bleeding the system or is it as simple as loosening the bleed screw and turning limit to limit a couple of times? I ask because another boat I wprked on had a dual outboard bleeding process that was fairly specific.
Thanks!
