I am working on a 2000 5.0 litre Mercruiser I/O with a brovo drive. a number of years ago, I had a problem with this boat overheating and found the water inlet from the IO was collaped, I repaired it and all was well for a few years. Most recently, this engine has had all new manifolds and risers + valve job. I diagnosed low water flow again, so, I put in a direct thruhull water inlet, blocked off the transom inlet and the manifolds run nice and cool now. However, now when I bump up the rpm's to plane the hose that goes from the thermostat housing to the circulation pump expands and looks like it's about to blow! I have changed the thermostat and the housing is clear. Manifolds are running nice and cool and a check with an infared thermometer is shiowing about 160-170 degrees. BTW, the circulating pump is new and the main feed hose to that pump is also new. Does this sound like a blocked engine blockage?? Any ideas would be helpful.
