Hi, I am new to this, but I have a issue with my Volvo 5 litre GXI in a 2011 Regal 1900 LE. When cruising at any rpm above 3000 for right around 10 min engine will all of sudden alarm and go into limp mode, pull throttle back shut off for a second restart all good, the more you do this the shorter the time frames become, the odd time the engine light will stay on.
I have a scan tool and scanned it showed a bad Crank positioning Sensor which I replaced now I get other faults main one being #12 bad intelligence device or component, plus I get miss fires almost always different cylinders. Also when checking scanner info and I see my octane is always at less then 10 sometimes on 0
But here is the weird thing we took off the big plastic air breather cover and it seemed to get better, then we took the spark arrester off and it almost never does it, spark arrester looks clean.
Thanks in advance for any help
