5.0 Mercruiser average running temperature and Oil Pressure?
madurodave
Still trying to get used to the new to me boat. What is your average running temp and Oil Pressure? Mine sat at 175-180 degrees all weekend, Oil around 40psi. What does yours run?
Re: 5.0 Mercruiser average running temperature and Oil Pressure?
Ayuh,... Your water temp is High,.... Should be 160? or 140?, depending on which T-Stat you've got...
Changed the Impeller lately,..??
Acceptable Oil Pressure for a SBC is 10lbs. per 1000rpms....
dvan1901
I've got a 2007 5.0 MPI (Mercruiser) and my temp is about 150'ish and my oil will be about 40 at idle and 60 when running.
madurodave
ruh roh! Glad I asked. Need to check the impeller!
Oil pressure seems to be ok based on "10lbs. per 1000rpms"
cpubud
my 2000 5.0 160 t stat runs at 165 to 170 , oil psi is 40 at idle and 45 to 50 psi running. new impeller at start of season.
gadget73
One runs 145, the other runs 160. Oil pressure in the 40-50 range. Every needle on the starboard engine is one needle width higher than the port motor, so they both probably run the same temp but I can't actually swear to it. Same thermostat on both motors, both impellers replaced at the same time (this year).
