Francin728
- Jun 13, 2011
- 27
I recently purchased a Donzi 19 LXR with a Mercruiser 5.0 and an alpha one stern drive (boat weights approx. 3000lbs).
The engine runs great I opted to rebuild the caurberator, replaced the plugs, wires cap, and rotor.
The problem I am having is when I accelerate the boat takes forever to get on plane. The engine revs to ~2800 rpms until it finally gets on plane at which time I can get up to 4000 rpms if I trim the drive. The drive has a 1.47 ratio (I am seeing 1.65 as standard for the 5.0L) and a 15 1/2X 15P prop.
I have tried contacting Donzi and Mercruiser for help with either a prop or any ideas and neither has been able to help.
Would a more aggressive prop get me on plane sooner so I can get up to RPM's or should I try a shallower prop to increase RPM"'s?
Any help is appreciated.
