I was running across the water today after it has been running flawlesslyfflawlessly the last two months since I bought it. It lost power and shutdown. This motor was replaced in 2017 and when I bought it, it only had 15 hours on it. I had a solid beep like the ignition key was on right before I start it. I turned it off and it didn't want to turn over at first. It acted like a weak battery. I gave it a minute or two and then it started turning over like normal but once it fired it started running really rough. Earlier in the day I noticed the oil pressure was a little high but it returned to normal 40psi pretty soon after. I'm not really sure where to start diagnosing. I'm fairly savvy with car/truck motors and outboards but not these. First one I've owned. It was suggested to me that the oil pressure switch may have failed but would that cause it to run rough? I've heard of "limp" mode kicking in when the computer detects some sort of failure. It didn't get hot but boy it sounds bad whereas it use to run whisper quiet and smooth.
Where to start?
Where to start?
