I have a 2003 5.0 MPI that is sounding the alarm every minute. I got the TechMate to read the codes, and in additional to the 4 code for sensors that are not installed, I get a 151 Fuel Pump Relay code. I can clear the code, but it comes back after a few minutes. The boat seems to be running normally, and all gauges are within normal ranges. I tried changing the relay, but that had no effect. Does anyone have suggestions as to what could be causing this?
