5.0 not starting
Greasy Greg
My 5.0 mercruiser overheated and shutdown when the hose from the stern drive came off. Hose was replaced but unable to start the engine due to no power at the engine gauges. Engine will turn by hand but no power to the ignition switch
Scott06
Look at 50 amp that is on the engine somewhere
Also
Might have blown the 90 amp fuse that is on the battery lug on the starter
Outside chance since it got hot the ground cable
On back of engine got melted ?
Greasy Greg
Also
The 50 amp push button reset on the engine and the 90 amp fuse on the starter as well as the ground cable checked out OK, thanks
How do I reset either of the safety shutdowns( the neutral safety switch and the temperature switch. Thanks
Greg
Scott06
Greg
the neutral safety and temperature switches do not require reset.
do you have 12v dc supplied to the 50 amp breaker or at the slave relay?
do you have a wiring diagram? is this a carb mpi or efi
Greasy Greg
Yes 12 v to 50 amp red button reset and also the slave solenoid
nola mike
No power to red, purple, or both?
