engine not started for a year. have replaced oil pan (had small leak) and replaced exhaust manifolds and risers. Put Mobil 1 engine oil in
did a compression test (engine has still not been started) all cylinders are at 210 - 220 psi except one cylinder is at 90.
have been told i should run engine up and do compression test again before considering a tear down. what say you guys any tips and advice welcome.
I took valve cover of and valves seemed to be operating ok
Engine ran fine before left up and has only 180 hours on it
VP 5.0 OSi GM smb 305 MEFI4
