I've got a 2007 Larson with the 5.0GL-H. It has a Holley 2300 2bbl carb (stamped 75030).
I have the carb torn down for a full rebuild after the accelerator pump diaphragm failed, and it started dumping fuel onto the manifold. Instead of just replacing the diaphragm, I figured I'd rebuild the whole thing as I've been having some hard starting issues as well.
What I can't seem to figure out is access to the idle mixture screws. I know there should be one on each side of the metering body, and I know on some models they are covered by plastic caps. On this one though, those plastic caps seem to be blocked by tiny 'detents' in the aluminum casting on the metering body. I can't get at them. Its like someone wanted me to not be able to access the mixture screws? Anybody else have this problem? :facepalm:
