5.0GL some ignition component gets damp.wet and runs rough
mikeneal
I recently flushed boat after a day of baiting (ran fine all day) and occasionally I will do a light. It's on engine to rinse since I boat in salt water. Last evening as I did it ( was still idling on muffs) it missed terribly after bout 30 seconds (post spray). If even stalled, was able to start it and ran badly for a bit then cleared mostly up. In automotive world plug wires would be logical start but somebody once told me wires in marine environment hardly age due to cooler engine compartment temps. True?
alldodge
IMO plug wires last longer in the marine world because they are not used as much. In any case if it misses when water is applied then its the same issue. Might be wires, cap or other connector
