Hi all - Great forums. Been stalking them for awhile, and now I need to ask a question!
I just typed a ridiculously long post, which got eaten when I pressed submit. Must have been a warning from the Forum Gods not to be so verbose. So, here's the short version.
2000 Maxum w/ 5.0L Merc, 2BBL, Thunderbolt V. I've run and maintained it for 2 years. 1st year ran flawlessly, and most of the second.
End of last season, we took the boat out on saturday, and ran all day. While pulling a towable that afternoon, the motor dropped from 3000rpm to near idle, but didn't stall. I throttled back and slowly brought it back up. Shortly after, it stalled completely. Couldn't start it again for an hour. Idled back to the slip.
The next morning, we asked the mechanic for advice, bought a new fuel filter, and anti-siphon valve. He checked the old valve and said it was bad - voila.
After 2 hours on the water, the same stall happened, and this time we needed a tow.
Left the boat with the mechanic. $450 in diagnostics and labor later, mechanic says we had a bad (ignition) sensor. We take the boat out the next weekend, and it sure ain't the sensor, since we stalled again. HE towed us back this time.
So - help?
Fuel - clean, fresh, gas, not old winterized stuff. You can smell it when you crank the ignition long enough when it isn't starting
Air - Throttle is opening when advanced - air should be getting in.
Spark - plug wires are new, sensor is new (obviously), mechanic checked out other components (though I don't trust him). I've ordered a new cap, rotor, coil, and other bits.
Could it be a carburetor issue? Something changing size or sticking when it is very warm? Float valve perhaps?
So - help?
