5.0L EFI Merc Fuel Pump Number?????
KetchiMan
Dshow
Re: 5.0L EFI Merc Fuel Pump Number?????
You might try -> http://www.showmetheparts.com/airtex/
Select the 'Med/Heavy Duty/Marine' tab.
Select your 'Make' (Mine is Mercury Marine)
Select your engine.
It will show your the Airtex pump part number you need, then search and find the best price!
Fun Times
Since you have a bravo engine you should have two fuel pumps going by your engine serial number.
You should have a low psi boost pump (861155A3) right before the fuel filter, Also you should have a high psi fuel pump (861156A1) way down under the exhaust on the port side.
FYI, Part number 861156A1 is FNLA (No Longer Available), Your merc dealer will need to reference service bulletin MCM SB 2004-05.
http://www.mercruiserparts.com/bulletins/001/04//2004/EN_05.PDF
http://www.mercruiserparts.com/Show...br=80&bdesc=Fuel+Filter+and+Boost+Pump(BRAVO)
http://www.mercruiserparts.com/Show...=8093&bnbr=60&bdesc=Fuel+Pump+and+Fuel+Cooler
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=884717
KetchiMan
Great info FunTimes, thank you very much for sharing your know-how. Got the right part ordered (with the help of a Honda dealer here in town) and I should have it tomorrow or the next day and hopefully be back up and running at more than 10 mph!
Sounds like you've done this job before....... If it ends up being the second pump, is that pump/cooler kit a really tough replacement? Remove the exhaust risers? Manifolds? Whole Engine?????
Thanks,
-Nick
