Are the exhaust manifolds interchangeable on 2000 and 1986 5.0l Mercruiser engines?
C carlos515 Petty Officer 1st Class Joined Aug 23, 2020 Messages 218 Jun 14, 2021 #1 Are the exhaust manifolds interchangeable on 2000 and 1986 5.0l Mercruiser engines?
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,412 Jun 14, 2021 #2 If you mean will they fit the engines ,Yes You cannot interchange wet with dry exaust manifolds and risers though
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,251 Jun 14, 2021 #3 carlos515 said: Are the exhaust manifolds interchangeable on 2000 and 1986 5.0l Mercruiser engines? Click to expand... Ayuh,...... Maybe,..... Which ones,..??..??
C carlos515 Petty Officer 1st Class Joined Aug 23, 2020 Messages 218 Jun 14, 2021 #4 I am looking at picking up a 5.0l that has a cracked block for parts. The manifolds seem to be wet joint in good shape. My Motor is a 1986 and the donor motor is the 2000 . Attachments exhaust 5.0l.JPG 145.7 KB · Views: 5
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 50,801 Jun 14, 2021 #5 So you wany to buy a broken freeze busted block for the most likely broken feeze busted manifolds? Your 1986 motor is an early 1-piece RMS block with flat tappet cam and the 2000 motor is a roller motor with vortec heads. What are you trying to do?
C carlos515 Petty Officer 1st Class Joined Aug 23, 2020 Messages 218 Jun 14, 2021 #6 Salvage the manifolds , starter , carb and ignition. Just finished building my 86 but need a starter and exhaust manifolds.
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 50,801 Jun 14, 2021 #7 But new manifolds and starter
C carlos515 Petty Officer 1st Class Joined Aug 23, 2020 Messages 218 Jun 14, 2021 #8 Ya I think your right. The way you put it makes sense. Just thought to save a buck.
