Andrew skier
- Jan 15, 2019
- 5
Hi all , question from Sydney AU
I have a 2006 bayliner with 5.0L injected mercruiser and Alpha 1 gen 2 leg .
was parked up due to covid and is back on the water today after engine oil change , impeller change and gear lube change .
in the water it comes up to temp and then the temp climbs and climbs - till temp alarm at 200 degrees and even limp mode
Let it sit and cool down etc finally back to dock and onto trailer
Normally temp sits at 175 and hardly moves
Start motor on trailer with leg in huge bucket so it has to draw water itself ( no hose / earmuffs pressure )
pumps heaps of water out transom plate holes and still temp climbs and climbs ....
suspect thermostat playing up
Remove and chuck in pot on stove - opens well before water boils , closes when out , reopens in hot water again
suspect i have put impeller in ass about ..
Drop bottom off leg and check impeller , all good right way in -
speak to local dealer ...
Remove rest of leg and just leave transom plate on so can start engine ( ive split leg so gear oil is out )
Jam hose directly into transom plate to eliminate any leg / impeller issues
thermostat back in - temp still climbs
thermostat out - temp still climbs
thermostat housing feels very hot - and as temp alarm and temp guage are on different senders trust they are reading correctly
Still lots of flow of water through engine and out transom plate
remove engine circulation pump and check - all good no cracks , busted vanes etc
Exhaust manifolds and risers done 3 years ago
No rust etc on impeller housing when removed - so no indication of flaking stuff etc
when running engine there is hot water flowing out of the two smaller outlets of the thermostat housing
Have removed bottom hose where water feeds up to engine water pump (from steering oil cooler etc ) water flows freely from transom plate to water pump inlet
Not sure where to head from here ....
all the Merc guys i have spoken to are lost as well
It seems to me that the water is not getting out of the engine quickly enough .... ????
Any help appreciated
Thanks
Andrew
Thanks
Andrew
