Hi All,
I have been using this site for years now and found all the answers to my various little faults without ever needing to post a question. Well that was up until now.....
I have a no spark issue with my Mercruiser 5.0l MPI engine. It turns over at speed and has a fully charged cranking battery.
I have recently had the ECM tested on another boat and that is fine, i also have swapped out the crank sensor as i thought it was the culprit, but still no spark.
On the coil i am getting 12v if i take an earth of the engine, but only 9.6v if i use the white and green wire from the coil driver. i think this is ok....
The intterupt switches on the gear link is all new and working correctly so not that.
Basically i am stumped and would like any help of you guys.
thanks in advance, Neil
