5.5 wont idle in gear low speed
oneribshyguy
First timer here... I have a 57 Johnson 5.5 seahorse compression is 70lbs each cyl took carb off and cleaned... needles hi n low looked great. new gas, she runs fine hi speed (adjust hi speed first) screwed low speed al the way in backed off 3/4. But as soon as I put it in gear and try to adjust low speed it eventually dies no matter where its adjusted... I go one way in small increments n then the other until she stumbles... Is it maybe points or timing NEVER PLAYED WITH THAT STUFF. Id probably really mess that up.... HELP!
Daviet
Re: 5.5 wont idle in gear low speed
You arn't trying to idle the engine to slowly are you?
You might want to check the spark, make sure it will jump a 1/4" air gap and is bright blue.
What plugs are you using, are they gapped properly?
ddwilson
Try readjusting high speed should start at about 3/4 but low speed should start at about 1 1/2 and adjust in @ 1/8 increments from there.
OptsyEagle
another check is to verify that your timing advance is set correctly. As you turn the throttle grip you will notice that a throttle cam comes around and pushes on the carburetor's throttle roller. There should be a line or mark on that throttle cam. When the throttle cam JUST touches the carb's roller, that mark should be in the middle of that roller. If it is not, there should be a couple of screws on the starboard side of the cam that can be loosened to adjust the throttle cam.
Make sure the choke is NOT engaged when you are doing this link and sync. adjustment.
HighTrim
You are gonna have to pop that flywheel off to have a look at those original cracked coils ;)
