Hello all, new to the boating community. I have recently replaced the impeller on my 5.7 mercruiser 350 mag. Alpha Gen 1. It was in neutral when I took the Lower end off. Put all new parts on. Put it back together and now it will not go into gear. When I start it, and attempt to put it into gear it will stall. Also during the time I had the lower end off I discovered from videos that most people put them in gear beforehand. My father told me to put it in gear at that point then put it back together. Tried that and it wouldn’t go into neutral at that point. So took it back out and started over while the shifter was in the neutral position thinking that was our problem. Now won’t go into gear. Please help.
