After cooling water leakedge at the thermostate house the engine was overheated. Now one week later the engine lost power. I checked the oil end there is water in it. At bottom of oil pan and visible at inside valve cover.<br />What is most likely the problem?<br />leaking cilinderhead gasket / leaking exhaust elbow / broken exhaust manifold / cilinderhead damaged? Someone any suggestions?
