mr300z87
- Sep 15, 2010
- 698
Today I started to winterize my Mercruiser 5.7 L 260 Bravo 2 and while running on the hose I noticed the port side manifold and riser were way hotter that the starboard side. I also noticed the water coming out the port side of the transom housing was also hotter than starboard. I ran the engine for about 15 min and the temp gauge stayed right at 140 degrees. I just purchased the boat which has not been used in several years so I do not know of any over heat issues. As preventive maintenance I remove both risers to inspect and replace the gaskets. All looked to be OK both flappers were intact so there is no sign of overheating. Is the port side temp higher because of the limited flow produced by the hose or do I have a clogged exhaust manifold and riser? Which need to be replaced. When I drained the manifold this afternoon I notice there was a lot of debris clogging the drain and I had to clear it with a wire. Thanks in advance for advise.
