I am running my fresh 5.7 longblock set up on the engine stand. It is a mercruiser 1995 setup using centerrise manifolds, thermostat housing, etc. all is well but for two issues:
1) I see the starboard side of engine water flow out the exhaust is less than port, the riser on the starboard is hotter than port. I can put my hand on the port side riser and leave it, the starboard I can grab it, but not for long.......is this bad? how to fix?
2) tiny(just a drip)of water from one of the manifolds to the brass elbow fitting on the bottom of the manifold......I have tape on it, and I am a little worried about turning it in another 360 degrees. what is the proper thread coating for this fitting?
thanks
thanks
