You may have thought to yourself, why is this guy looking at check balls and asking about waterflow. The motor is like new with only 5-6 20 gallon tanks run through it. We constructed a Glen-L Monaco and put the 5.7 CARB/SKI inboard right from the crate. It has a beep sounding out of the little horn that comes with the wire harness from day one. Running the engine anywhere over 1500 rpm may result in a blast, but it is usually when revving faster the horn sounds more often. Without the check balls in all of this beeping goes away. From the manual, a beep may indication of a water flow problem, The raw water intake is positioned near the stern of the boat as the plans indicate which results in a long 6 foot hose to get from the strainer scoop to the raw water pump. Yes the intake hose is correct with the wire reinforced un-crushable hose. A 90 degree elbow between the scoop/strainer and the intake hose is required to get the hose aiming towards the raw water pump towards the bow. Any suggestions would be very appreciative. I think the intake hose may be too long. Can't remember what the installation instructions with the crate motor said exactly, but I'll have to take another look at them.....Thank-you in advance !
