5.7 Mercruiser hard starting with hot engine
longlakejeff
Hi all, looking for any suggestions. I have a 2001 5.7 efi. I have had this boat for over 15 years and it is always well maintained. This your it started giving me trouble with starting after we have been out. after it sits a period it starts right up. Looking for ideas of things to check. Thanks.
alldodge
Howdy
It sits just a little while and is hard to start, but if it sits over night all good, correct?
If this is the case, most likely it needs a carb rebuild. The carb is leaking fuel after it stops and is flooding
Ayuh,..... Welcome Aboard,..... Inspect the Contents of the fuel filter, for anything but clean fresh gasoline,......
longlakejeff
Thank you guys. All dodge that is exactly correct. Bonds have done that and replaced filter/separator. Thanks again guys, will investigate the carburetor further.
im confused.
post #1 says EFI
however post #4 says carb
which one is it. if you dont know, post a picture and the serial number
longlakejeff
it's the throttle body injection. I'm not totally familiar with it but I understand it's a kind of a hybrid between standard carb and injectors.
