Re: 5.7 Mercruiser, No bottom end power, throttle sluggish, horrible porpoising HEL
I havent made any changes to the boat since I bought it. Sorry, dont know what "hooked" is. Engine sounds like it is running ok, but lacking rpm's maybe. In nuetral revs beautifully.
Ayuh,... Welcome Aboard,... Hold a straight edge against the keel line on the bottom of the hull,...
It should be Straight for the last 4 to 6',...
If ya see daylight under the bar, that's a Hook,...
If the bar rocks over a hump, that's a Rocker,...
Revin' in neutral is irrelevant,...
Do a compression test, 'n tune up,...
What prop pitch, 'n blade design is on it,..??
What rpms is it runnin' at Wot,..??
