Replacing all the bellows because of the one cracked boot? That seems excessive, I'm not very mechanically inclined, but you'd think I would just need to replace that one boot?
buying a new to you boat and not going thru all the drive preventive maintenance such as bellows, raw water pump, gear oil changes, drive alignment, gimble bearing check and u-joint check is simply foolish. its called preventative maintenance since that little torn shift boot can sink your boat. the main bellows can toast your drive, gimble bearing and input shaft. sagging isolator bushings can cause misalignment which will tear out your engine coupler.
I am assuming you did the engine maintenance as well
excessive - not really, its whats required to keep your boat floating and running without costing you thousands in toasted drives or salvaging your boat from the bottom. welcome to boat ownership the most expensive hobby short of owning race horses and airplanes
there are two types of boaters, those that do their own maintenance and those that pay other people to do their own maintenance
