5.7 not exceeding 2500rpm after breakin
lord1234
I put in a brand new Vortec 5.7L to replace my VP 5.7L. It broke in great, went up to 4k and even above...but after break in for some reason it doesn't want to go beyond 3200RPM, even full throttle to the engine. It will go well beyond 5k in Neutral, no problem, but under load, no go.
Mechanic is guessing timing, but I was hoping not to adjust the timing. Where else can/should we look?
in neutral there is no load, the motor would run there with very little fuel or only 1 cylinder
however under load, you need lots of fuel.
most likely you have a fuel system problem
why are you adverse to verifying the timing?
alldodge
Engine Prefix 2143. Serial number 10084
The motor serial number is about 10 digits
Let's put it this way, right not we know its probably a VP because its in the VP section
Its a 5.7L but other then that we don't know
It could be a carb, efi, mpi, and don't even know what year,
Good luck
lord1234
Its a 2017 5.7L Vortec, that was used to replace a VP 5.7GL-PLKR (1997).
It's got a 4 barrel Edelbrock carb.
Note I didn't see a Vortec forum to post in so I posted here.
alldodge
OK its a 1997 5.7 GL which was up dated to a 17 vortex. Cool know much more about what your working on, thanks
Vortex just means different heads and intake, same basic motor
Assuming it still has the Delco EST ignition system, only the GL-A had prestolite and rest had EST
Timing would be at 8 BTDC
Connect a timing light and see if the timing is advancing as rpms increase, and by how much
Also leaning toward not getting enough fuel if the timing is advancing
You getting any backfire when at WOT?
lord1234
So the good news its none of these:
The connectors on the fuel pump were coming loose at random and causing fuel starvation! Figured that out and all fixed :)
