5.7 Raw water hoses
torombolo
Afternoon, I want to change all of my Mercruiser 5.7 raw water hoses, Ive attached an old pic. of my motor exept that now it does not have the water heater hoses those were removed.
Anyway can anyone direct me to a chart or diagram were I could get the part number to order either on line or locally?
Motor is 2001 with a Bravo 3
Thanks in advance for ALL your help!
Fun Times
Re: 5.7 Raw water hoses
Hi there, it would be better if we had your engine serial number to ensure the correct parts are being found, but since you have an 2001 carbureted 5.7, this should get you what you need.
https://www.mercruiserparts.com/Sho...r=2697&bnbr=110&bdesc=Standard+Cooling+System
https://www.mercruiserparts.com/sel...c_nbr=5.7L++(2+BBL.)++++GM+350+V-8++1998-2001
Also if interested, once you find the part numbers needed, you should be able to run the number through iboats parts search inside this next link at the top of the page to see if they have what you need on hand for you.:) http://www.iboats.com/Boat-Parts-Accessories/dm/
Good luck.:)
torombolo
Thank you fun times, I have a problem with my serial, I know where it should be but the little plate with the number is long gone.
Again thank you for the help and links.
