I have a 1998 5.7 GS - this season I noticed that the temperature was a little high and erratic at speed so I put in a new 160 degree thermostat - today running at idle/ slow the temperature stays dead at 160; running at 2500-3k it is going to 180-185 - and staying right there - I rant it WOT and it went to 190 - as soon as I slow/ stop it cools fine - the boat has a new raw water pump and impeller in the last 10 hours as well. From the rear at idle it appears plenty of water is coming out the back. the recirculation pump does not appear to be dripping (no water is leaking in the engine compartment). My mechanic is telling me this is not unusual and I should not worry about it and that if the recirculation pump was going the temp would just keep rising - I am wondering if it is going out / missing a blade.
Is this truly normal? the boat has never done this before - but last season I did put in a new (used short block) - new manifolds and risers so I do not have many hours experience with the motor..
thanks in advance for any Thoughts/ ideas...?
