5.7 thunderbolt weak spark
Status
Not open for further replies.
westie612
Have a 87 5.7L 260 hp mercruiser alpha 1 with t-bolt ignition. I have been through the Seloc manual and have followed the troubleshooting. Not alot of info avail. Ultamatly it suggested to replace the sensor inside the dist. I have also replaced the cap, rotor and coil. When I place coil wire 1/4' from ground spark is yellow not blue. even weaker at the plugs. When I crank the engine it almost starts right away. Have tried starting fluid with same results, assuming it's not fuel delivery. Any suggestions
Re: 5.7 thunderbolt weak spark
Ayuh,... Welcome Aboard,... Do ya have a full 12v at the (+) at the coil,..??
westie612
Oops! No with the key on = 0 volts. while cranking = 3.8 v
Maclin
When you say "across coil" what do you mean? The voltmeter negative lead should be on a good engine or battery ground. The positive lead of the voltmeter goes to the positive terminal on the coil, that will give you the voltage at the coil.
westie612
Thank you! your very helpful. Ground to the + side of coil is 12.9v with the key on. drops to 8.4 when cranking
Don S
Shouldn't be dropping that far. Check clean and tighten all battery cable connections (Both positive and negative cables and each cable has 2 ends)
If they are clean and tight (With a wrench, not with a wing nut and your fingers) then get the battery load tested. It's showing too much voltage drop.
With that low of voltage while cranking I would have to bet the starter even sounds slower than normal.
westie612
1 new battery. other tested good with a load test. cleaned connections when I replaced the batteries 7 days ago. New starter too.
Don S
It's not going to start with 8V to the coil while cranking.
Ayuh,... Check the Other end of the battery's Ground(-) cable,...
You could also have a Bad cable,... or more likely, cable End,...
westie612
I will check all cables and the selector switch. Thank you all for your help....much appreciated....but for now, there is a prairie dog town calling my name in South Dakota
Ajsikora24
I am having a very similar problem on a 1982 Mercury 5.7. Weak spark at coil.
Mine is a new engine as of last summer with new coil, distributor, slave solenoid, starter, plug wires and alternator. 12 ish on the positive and negative side of coil with ignition on and as low as 4.5 when starting.
Still trouble shooting but I’m interested in any suggestions
thanks
Status
