5.7gsi pefs surges/backfires/will not stay running when cold
TrentD
So I bought this boat and on the sea trial it would not plane with the starboard motor back firing and no power (revved fine in neutral) so the guy had a mechanic look at it and had the fuel pump replaced part number v21608511 the following sea trial it ran great and I wrote the check, 2 weeks later I go down to the boat and put 40 gallons in each tank, we ran about 30 to 45 mins at about 3200 Rpms up river in 1 to 2ft seas when we stopped to pick a friend up a friend idled in to the pick shut engines down briefly, idled back out and took of up river this time about 10 to 15 mins in the engine started to backfire periodically a single backfire every few minutes before too long the engine was loosing power and back firing to the point we couldn't really take it over 2k.....fast forward it's now at its new home 90 miles up river. I changed the filter and pored it into a jar, there was some nasty **** in there.
That's a link to the photo of the fuel, but anyways, it didn't change anything, I have since ran 20 more gallons through and added about 30 to the tank. With sea foam and no change, I did notice that it will go nicely but once it reaches about 3000 it will stall unless I wiggle the throttle I can get it to almost 4k and no back fires but I have to constantly wiggle the throttle to maintain those Rpms if I do not it will back fire sputter and stall, if I'm modestly chugging along around 2000 rpm it's fine.
I did notice in comparison to (reving) the starboard vs the port while in neutral the port is very responsive off idle and the starboard all though it revs good there is a major delay if you goose it off idle it will stumble then rev fine through the Rpms it's just if you goose it off idle its like it cuts out for a half a second then goes.
My appologies for the lengthy message just want to make sure I relcieve more insight then comments asking for more details :)
Engines have 205 hours on them and compression is good
Re: 5.7gsi pefs surges/backfires/will not stay running when cold
Ayuh,.... Sounds like the fuel system is full of Crap,... Til it's completely Cleaned, yer gonna have this Issue....
Have ya rechecked the filter,..??
ENSIGN
You need to start by cleaning the tank.Mixing clean gas and dirty gas only makes more dirty gas...
TrentD
My biggest problem with the water n the fuel theory is that the filter was not full it only had about a half inch of water at the bottom, and how come adjusting the throttle "wiggling" allows the engine to come up to 4k and no back fire or stall, I rode like that for 20 min strait....no problems just have to constantly move the throttle...if you leave it in one position it will stall if you pull back it speeds up a little before trying to stall hence. the constant adjustment maintains rpms could this be a check valve? And are there any other filters other than my water fuel separator that could be stopped up causing flow issues
TrentD
5.7gsi serial number 4012003633
TrentD
Here is another possible helpful hint when I changed bothe starboard and port filters the port came apart normal and I emptied contents int mason jar, the starboard when I opened it it over flowed like it was under heavy pressure .......weird
