Hello,<br />I have a 5.7L 235 HP Alpha 1 Mercruiser. All ready to get started this boating season and I ran into problem. The power trim is not functioning properly. When I push the down button on the power trim, the engine lowers fine as it should, however, when I push the up button there is no reaction whatsoever, no sound or anything. So basically it is currently stuck as low as it goes. Would someone have a clue as to what problem could be? Someone at marina I am keeping it at said it is probably a bad 'up' solenoid? Is this true? Please help! Also, if it is solenoid,which solenoid on iboats would replace it 'http://www.iboats.com/mall/index.cgi?*******=857600398&**********=686800917&search_type=keyword&keywords=solenoid' ? Thanks so much for your help =]
