bullsnot
- Aug 22, 2012
- 57
I had posted a thread a while back about sputtering at full throttle. Thanks for the responses!
I tested the fuel pump and it is out of spec so I am replacing it. The new pump arrived and it looks very different from the original fuel pump. If I need to post pics then I can but in short the fuel line in and out are in different places but that's not a big deal as I'm pretty sure I can move the lines. However there is a clear line that goes from the base of the carb to the fuel pump on the original. The new pump has no where for this line to connect. I'm assuming this is a vacuum line and should just be capped at the carb? I know for a fact the part number is correct and I can only assume the aftermarket pump is intentionally different?
