Well I have put the engine back in my 1999 Glastron GS-205 (1997 model drivetrain)and it runs great. Only have two "small" problems left to contend with.<br /><br />The motor always starts right away when cold and cranks strong. It has a new starter installed. When the motor is hot it sometimes will not start. When i turn the key it will not click or anything. It acts like it doesn't have a cable hooked to the battery, I have checked the cables over and over to make sure of the connections are good. If the starter was getting hot and binding it would still click when I tried to start it, right? The motor is running at around 160 degrees with no overheating issues. When it finally does start up it cranks strong, I just have to wait a few minutes usually.<br /><br />Second problem is the engine is leaking oil where the oil pan contacts the timing chain cover. It only has this leak under WOT. I recently had engine out of boat and put a new oil pan on. Ran in the driveway with a flusher hooked to the drive for about one hour below 2000 rpm with no leaks. I originally thought the leak was around the timing cover seal for the crankshaft but upon closer inspection I am fairly sure the leak is between the oil pan gasket and the bottom of the timing cover, looks like it is only on the starbord side of the pan/cover also. I tightened the front oil pan bolts a little bit more(I torqued them to spec when installing the pan) but have not tested it again yet. I am running 20W-50 oil, I think I will change to 25W-40 or 40W oil as well.
