5.7L Rusty Starter - Shop Says Have To Remove Engine To Replace - True?
Dangit
My 1997 Chaparral Sunesta 252 has a very rusty starter that is still working. The battery terminal is loose too. I don't want to get stranded somewhere so I asked the shop if they could replace it without removing the engine, because of limited access they said no.
How much time is typical to remove and reinstall a 5.7L Mercruiser hooked to a Bravo III outdrive?
Thank you!
oldjeep
Don S
Re: 5.7L Rusty Starter - Shop Says Have To Remove Engine To Replace - True?
If you can't replace the starter without pulling the motor, don't expect pulling the motor to be any easier. I have pulled engines in 20 minutes, same engine in a different boat with the boat built around the engine, 5 hours to remove, and a lot longer to put back in.
Boat designers don't care that engines need fixed.
hookemdano
whats in the way of the starter removal? the manifolds? maybe remove the manifolds to get easy access to the starter...just a thought....I think this may be cheaper than pulling the motor....unless they cant remove the manifolds without pulling the engine...
thumpar
You might try taking some pics to post otherwise we have no idea because this is boat specific not engine specific.
Boat designers don't care that engines need fixing.
Ayuh,.... That's 1 of the fun side effects of doin' these Highliner refits,....
A Mechanic is team leader of the new installations, 'n access is priority #1...... ;)
