Hi Guys - first question here so hope someone can help. I have a MerCruiser 5.7L MIE GM 350 V-8 1988 rebuilt recently. Dipped and new rings, etc. Starts and runs beautifully, except on a number of occasions if you turn off the motor on the water, particularly after a hard run, the motor feels locked with a ‘clunk’ sound. It always restarts if you leave it for a short while to cool down. If we do not turn off the engine at idle, we never have a problem - but what a nuisance.
Couple points - water cooled open system fed from a jet. I have new starter motor and eliminated any hydrolock or vapour lock cause.
My guess is this - I’m getting a hot spot in one of the pistons (for whatever reason) and although the engine cooling is working perfectly - the piston is getting stuck until it cools sufficiently??
The engine gauges never show overheat (140-150F deg , and engine block doesn’t get above 200F even under heavy load.
The temp gauge goes up obviously when it is shut down.
Any thoughts? Prefer not to have to rip the motor down
. Is there any possibility there is not enough pressure through the block given its open cooling. Pressure from jet doesn’t get above 2-3PSI at manifold so I’m thinking a bypass supplementary 12V water recirculating pump might just help?
Sorry long winded - tried to provide as much info straight up. Much appreciated.
Tim
Tim
