Hello all,
5.7 1996, thunderbolt V merc cruiser, 2 barrel carb:
Rebuilt the carb in May, ran great for 2 tanks of gas. The boat sat for 6 weeks and now it surges at 1200 thru 2600 rpm, I see gas dripping from right jet looking down at the carb at mid range rpm. It won't idle or holds at 500 rpm. Electric choke is OK. Stalls when i give it gas. seems to run good at 3300 + rpm.
New plugs, cap, rotor and timing last fall.
I found a little whitish-greenish crud in the filter at the carb and I emptied the water separator, no water but 6 small red flakes.
Is their a filter in the tank and in the fuel pump?
